40
This discussion topic has been answered Discussion topic: How do you cancel Lionsgate on Sky
This message was authored by: jazzyjeffy
How do you cancel through your Sky account the subscription for Lionsgate that was arranged through the Sky Q box?
Many thanks l.
This message was authored by: Debra2023 Answer
Re: How do you cancel Lionsgate on Sky
According to Lionsgate you can cancel Lionsgate+ via the Sky Marketplace.
The easiest way to access Sky Marketplace on Sky Glass is to say ‘Hello Sky, go to My Sky’.
If you have a Sky Stream puck or Sky Q, press the Voice button on your Sky remote and say "My Sky".
If you don’t want to use your voice, follow these steps:
  • Press Home on your Sky remote, then select My Sky at the bottom of the screen.
You’ll then see a screen with your purchases. Select Your products. You’ll then be asked to enter your Sky TV PIN number.
Then follow the prompts to cancel.
You can cancel services by phoning Sky directly
Avatar for jazzyjeffy
Yeh I tried that and ended up speaking to somebody in a call centre in India who couldn't understand me and then went on to tell me that Lionsgate isn't showing on my account, yet when I check my bill on Sky they are debiting me £5.99 for it. The customer service is an absolute joke.
This message was authored by: Grono82
Thanks this has worked thanks for info 😃😃
This message was authored by: NikkiEas
Thank you so much for that I've been on both sky & lionsgate apps for hours trying to work it out!
This message was authored by: Jam99
I've got lionsgate but it's not showing up on the my sky app. How do I cancel?
@Jam99  Please see the post marked as Answer
That doesn't work. Nothing shows up on my sky account. Lionsgate say I need to contact sky and nothing shows up on sky
@Jam99  Are you doing this through your Sky Q box?
I've tried via the app my sky and via my sky stream box
@Jam99  You'll need to call Sky I'm afraid.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
This message was authored by: Moleseee
Thanks for the info, this worked.
How come it is so difficult to cancel anything through Sky. Anyone else is completely transparent with there signup and cancellations. Sky is so unintuitive, and on their website it is impossible to find a cancellation option, or even a phone number. Even their chat bot is useless. Sorry for the rant, but someone at Sky needs to sort this out.
This message was authored by: rits
I've been trying to cancel LIONSGATE+ for three weeks now everything I have tried does not work I will have no option but to call sky, I have done all the prompts I go onto my sky. I press the right buttons that when I get to the page, all I get is the Lionsgate app I click on it and it just opens the screen and it says start watching I don't want to watch. I want to cancel it. It's so frustrating.
This message was authored by: Doc5907
@rits
Try the following exact procedure on your Sky Q box...
Press Home
Scroll down and press My Sky
Scroll across and press Your Products
Enter your tv PIN number
Scroll down and presss App subscriptions then current
Highlight Lionsgat+ monthly and press enter
Scroll down and press Manage subscription
Scroll down and press Cancel subscription
Press confirm
After a few seconds you should get confirmation on screen
Sky Q 1TB UHD
LG TV
Sky Mobile
Answered - Go to Answer
