Discussion topic: How do I cancel bt sport
This message was authored by: Dave+Wal
Re: How do I cancel bt sport
@Dave+Wal  If you have it throgh Sky you need to contact them by  calling  or use the following link https://www.sky.com/help/articles/cancel-sky-tv#contact-leave
On the link provided (In the UK) it should include a Message Us option between 0900-1930.
You can also call on 150 from a Sky Mobile or Sky Talk line
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
If you don't see the Contact options on the link above make sure java script is enabled on your browser.
Hi @Dave+Wal
You need to contact whoever you are subscribed with (Sky or BT).
If with BT you need to give at least 30 days notice.
With Sky you may be under contract.
