Discussion topic: How do I cancel bt sport
Message posted on 30 Jun 2023 10:42 AM
Message posted on 30 Jun 2023 10:43 AM
Re: How do I cancel bt sport
@Dave+Wal If you have it throgh Sky you need to contact them by calling or use the following link https://www.sky.com/help/articles/cancel-sky-tv#contact-leave
On the link provided (In the UK) it should include a Message Us option between 0900-1930.
You can also call on 150 from a Sky Mobile or Sky Talk line
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
If you don't see the Contact options on the link above make sure java script is enabled on your browser.
Message posted on 30 Jun 2023 10:45 AM
