This discussion topic has been answered Discussion topic: How do I add ITV Meridian South as an additional channel
Message posted on 03 Mar 2026 11:01 PM
I am on the border between ITV London and ITV Meridian South. What are the channel parameters to input on Additional Channels, please?
Message posted on 04 Mar 2026 06:46 AM - last edited: 04 Mar 2026 06:51 AM
@SteveDAldershot wrote:
Thanks, I had been trying that but it says "No Channels Found".
I'll try switching box off and restarting it in the morning. Cheers.
All the parameters that @xenon81 listed are correct, so double check that you select them all - it does tend to default to other parameters for most
P.S. If you added the channels sometime in the past you may need to delet the old entries first
you should get 7 ITV regions listed, which as @xenon81 indicated , all get listed as ITV 1 with no detail of which region
BTW you possibly know but in case you don't when added manually, you can only watch live via the Manual Channel menu entry as they are not added to the EPG
Message posted on 03 Mar 2026 11:14 PM - last edited: 03 Mar 2026 11:16 PM
Re: How do I add ITV Meridian South as an additional channel
11344 H
27500
2/3
8PSK
DVB-S2
There are 7 ITV1 HD regions on that transponder including Meridian South, Meridian Thames Valley, Meridian East.
You will need to add them all then check during local news to find which is Meridian South.
Message posted on 03 Mar 2026 11:21 PM
Message posted on 04 Mar 2026 08:39 AM
Thank you to both of you.
Problem solved, I had deleted the channel in error, was being driven to distraction in not being able to re-instate it, think I missed the "DVB-S2 option!
Thanks again.
