Discussion topic: High contrast mode
Message posted on 08 Jun 2023 10:18 PM
High contrast mode
Hi,
I usually have my accessibility setting to high contrast for the black background. But it's now turned back to blue with no explanation and is stuck in this mode. How do I turn it back to black?
Message posted on 09 Jun 2023 06:39 AM
Re: High contrast mode
@Green+grass+4 wrote:
Hi,
The setting is in :
Home - Settings - Accessibility - High Contrast
If that doesn't appear or let you change it I suggest you try a power down restart:
Use the remote to place it into standby mode
Then remove the power to it (either switch off at mains or remove the power plug)
Wait at least 30s
Then re-apply the power & wait for it to fully restart - this may take a few minutes.
Message posted on 09 Jun 2023 07:01 AM
This has happened to my box a few times over the years, when I've enabled high contrast.
You will need to power reset your Sky q box and set high contrast back to On in the accessibility settings;
Home>Settings>Accessibility>High Contrast
