Discussion topic: Viewing card help
This message was authored by: niccraig
Viewing card help
My sky q box has all of a sudden started showing a message "please ensure the correct viewing card is inserted with the chip facing up"
I have done the turn off etc and reinsert the card and still no joy. Any ideas of how to resolve this as my 2 additional boxes upstairs are not working I assume because of this.
This message was authored by: Invisiblename
Re: Viewing card help
Try removing the card & giving the chip a gentle wipe with a soft cloth. Then reinsert it (chip up) and make sure it clicks in place
I am just another Sky customer!
This message was authored by: Ggooo
Getting the same random message saying "please insert correct viewing card with the chip facing up".
Tried turning off the power & removed, cleaned & re installed the viewing card but nothing has changed.
Avatar for niccraig
Hi tried the various trouble shooting methods many times with the same result "no sky" thanks for the reply though. Think this one is going to be a long dragged out process.
@niccraig I have escalated this to sky
You may receive an email or a private message inviting you to have a private conversation on the Community with a Sky Expert.
Look out for a chat bubble at the bottom of your screen inviting you to a chat
If you are using the Safari browser please make sure that Hide IP Address is not checked in order to see the chat bubble. If you are having trouble finding this to check the settings, use another browser such as Firefox, Chrome etc.
The link below explains how the escalation process works
@Ggooo I have escalated this to sky
This message was authored by: Addie15
Hi there! Thank you for escalating this. We have sent an invite to niccraig.
My problem appears to have been sorted.
I did the card wipe again last night & all returned to normal.
As it happened to 2 totally unrelated users on the same day & around the same time suggests it was probably a software issue or a problem with Sky itself.
I've never removed my viewing card before, didn't even know i had one or where it was, so clearly it wasn't in the wrong way round
This message was authored by: Lisa-P1987
Update - Spoken to niccraig, after a few checks, we replaced their viewing card 🙂
Lisa - Sky Tech Team Expert
This message was authored by: Rosie49ames
Same thing has happened to me they sent me a new sky box so I can watch TV now but cannot pause or rewind I guess I need a new viewing card how can I get one as can't get through to a human on the phone
@Rosie49ames You could try refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
