Discussion topic: Hidden menu
This message was authored by: dsr1000
Hidden menu
I set a pin so my kids cant access the apps with out putting pin in.
But they cleverley have found a way to over ride this.  As they access the hidden menu by going to settings pressing 001 and select button.  Then they go to Reset section and  and do a reset.  This over rides all pins and remove pin requirment and they then access apps like youtube.
How can I stop this!!
Re: Hidden menu
Other than physically restraining them, you can't.
Hide the remote?
Re: Hidden menu
Hide the remote?
If they are that savvy, they will use their devices as a remote?
Avatar for dsr1000
Re: Hidden menu
Surley sky needs a more full proof robust parental control.
They went on mums phone and chat gpt and found answer.  They only 10 years old.
Re: Hidden menu
Q is a decade old and has a few years left as a product: it's not going to change now.
If they have unsupervised access to a smartphone then they can access far worse things than YouTube if they want to...
Re: Hidden menu
Welcome to being a parent in the 2020s
how come their mother's phone wasn't locked itself?
