Discussion topic: Sky q box
Message posted on 20 Feb 2026 06:55 PM
Sky q box
Sky q box keep losing the wy fi the feeds the mini boxes
Message posted on 20 Feb 2026 07:06 PM
Re: Sky q box
Hi @Edward+zwhereat
Reboot the minis as above.
If the minis still does not connect reliably try a Network Reset on the minis. Start with the one nearest to the main Q box
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router (not Sky Max) if on Sky Broadband or previously connected mini).
