Discussion topic: Network dropping continually
Message posted on 16 Feb 2026 10:04 PM
Message posted on 16 Feb 2026 10:05 PM
Re: Network dropping continually
Message posted on 16 Feb 2026 10:15 PM
@BEACON27 If you are not a sky Broadband Customer you have to set the sky Q up on a third party network connection!
Message posted on 16 Feb 2026 10:45 PM
Message posted on 17 Feb 2026 06:43 AM
@BEACON27 Use this link from the sky Help below!
Message posted on 20 Feb 2026 02:29 PM
Im having to do this 'reset' 4 or 5 times a day. Often in the middle of watching something
Message posted on 20 Feb 2026 02:38 PM
@BEACON27 Say who is your broadband supplier now and which Hub you are using from them!
Message posted on 21 Feb 2026 12:14 AM
One thing you can try is splitting the 2.4 and 5GHz channels on your router, through its web admin interface, to 2 differently named SSIDs then only connect the Q to the 2.4 network as it can only use that. Might work. Maybe.
Q is terrible with 3rd party wifi.
