Discussion topic: Hi, my sky tv is saying I’ve lost connection to the sky box. I rebooted the router.
Message posted on 17 Jan 2024 10:03 PM
I've disconnected my router and rebooted, rebooted the sky box. WiFi is fine as I've tested it (70mb).. how can I fix this?
Message posted on 17 Jan 2024 10:10 PM
Re: Hi, my sky tv is saying I’ve lost connection to the sky box. I rebooted the router.
Hi @Dave+44
Try a Network Reset found in Q box Home - Settings - Setup - Network.
