Discussion topic: Hi - mini box connection keeps dropping to sky Q box. I’ve tried reset
This message was authored by: PeterDodd
Router reset and main Sky Q box all connected but mini box connection keeps dropping
Re: Hi - mini box connection keeps dropping to sky Q box. I’ve tried reset
Hi @PeterDodd
Reboot the mini as above.
