Discussion topic: Hi I have a skyq box connected to a Samsung smart tv. The light on the box is green but on pic on tv
This message was authored by: Bav2
The sky remote red light is not coming on when buttons are pressed so not sure if it's a sky remote problem or a skyq box problem
Re: Hi I have a skyq box connected to a Samsung smart tv. The light on the box is green but on pic o
Hi @Bav2
First make sure that the TV is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
Just for info the light on the Q remote will only illuminate Witt the Question mark :lia_question-mark: button and the Microphone button.
Avatar for Bav2
Hi
Unfortunately that hasn't worked either. Any other ideas please?
it feels like the remote is only switching things on and off and not doing much else.
@Bav2 wrote:
Hi
Hi @Bav2
Have you tried completly resetting the remote?
Avatar for Bav2
Hi
Yes I did that and it's all working now.
Thank you so much for your help, I really appreciate it.
