3
This discussion topic has been answered Discussion topic: Help needed
This message was authored by: JJAY87
Help needed
My mini box isn't working. When I put the power on the red light comes on and then In a couple of seconds the red light disappears and doesn't come back. It stays blank. Anyone know how to fix this.
Re: Help needed
Hi @JJAY87
Try working through the following link
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Re: Help needed
Hi @JJAY87
Avatar for JJAY87
Re: Help needed
Thank you but I've tried whats on the link.
Re: Help needed
Then you know the conclusion @JJAY87
To complete the recovery procedure on your Sky Q Mini box:
  1. Switch the Sky Q Mini box off at the mains.
  2. Hold down the Reset button on the back of the Sky Q Mini box and switch it back on at the mains.
  3. Keep holding it until the light on the front flashes red and green. This will take about 30 seconds.
  4. Once it flashes red and green, press the standby button on the front of the box.
If the lights don't show after 30 seconds, repeat steps 1 to 2. If it still doesn't work, you might need to replace your Sky Q box.
