Discussion topic: 2 TB Sky Q Box Locking Up Daily
Message posted on 28 Apr 2023 12:11 PM
Usually happens overnight, but has frozen mid day as well. Unresponsive with red and green light on, only power reset works which may fix for a day or so.
Tried, turning off 2.4 and 5GHz wireless, making sure lots of recording space, tried all the standby modes (None/Active/Eco) and "reset settings" option from the engineer menu. The Sky Q box is hardwired to 1gb internet worked fine for 3 years.
Signal strength fluctuates between 70 and 80
Signal quality 90
LNB type Wideband
Software version Q210.000.06.03L (5k4107v)
Hardware Version 32B206
Feels pretty terminal at this point, unless anyone has an idea.
Message posted on 28 Apr 2023 02:14 PM - last edited: 28 Apr 2023 02:14 PM
Re: 2 TB Sky Q Box Locking Up Daily
Quite possibly, yes. Sky will almost certainly just swap-out the hardware by courier: make sure you remove the viewing card first.
Message posted on 28 Apr 2023 05:44 PM
New box on the way by courier, exactly as you said. Hopefully, it resolves, even if it doesn't I can start looking at the environment outside the sky Q.
Message posted on 28 Apr 2023 06:36 PM
@callofduty AS @TimmyBGood sayscremember and remove your viewing card from the old box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 01 May 2023 01:53 AM - last edited: 01 May 2023 01:54 AM
Box swapped. Seems resolved. It was actually 1TB box not 2TB. I did notice on the old box, calcuting by extrapolation, it only took about 500GB of recordings for it to register 100% full. On the replacement this seems to be up to 700GB not sure if this is relevant tbh.
