Discussion topic: Hello
This message was authored by: AVS2
Hello
Hello
My sky box Q I cannot record or download problems as it says the Hard drive problem.
thank you
Re: Hello
You'll probably need a new box: https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Remember to remove your viewing card for a box swap.
Avatar for AVS2
Re: Hello
@PandJ2020
i have ordered a new box from sky
thank you
Re: Hello
@AVS2 wrote:
@PandJ2020
thank you
Make sure, when the courier arrives with your Sky Q box replacement, you remove the viewing card from your current faulty box, as you will need this for your new replacement box.
