9
This discussion topic has been answered Discussion topic: Hello message always at start up
This message was authored by: FTB1
When starting Sky Q a hello message has started appearing every time,  always used to just go to the home page? Any ideas to stop it?
This message was authored by: Mark39 Answer
Re: Hello message always at start up
Sky Q boxes aren't designed to be disconnected overnight. Providing you have the box set to Eco mode their overnight power use is negligible.
This message was authored by: Invisiblename
Are you sure it's from Sky and not your TV?
I am just another Sky customer!
Avatar for FTB1
No it's Sky, says hello, press home and wait!
Are you powering the box off?  (i.e. at the plug?)
Avatar for FTB1
Hi, Yes the box & TV are connected to a smart switch and Google turns them off on command.
Avatar for FTB1
But this has always been the case and the Hello message only started a few weeks ago?
So the answer is not to turn it off.
Avatar for FTB1
I see your point but as I said we turned it off before and this didn't happen,  also everyone is doing their best to save energy, I turn almost everything off at night.
Avatar for FTB1
Fair point, I will try it, thanks.
