Discussion topic: No signal G52 area
This message was authored by: BrianAnnall
No signal G52 area
Anyone else in Glasgow G52 not getting a signal
Re: No signal G52 area
Hi @BrianAnnall
Satellite signal does not affect areas unless it's due to heavy cloud or storm cover.
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Alternately, if you are on a Communal Dish you will need to contact your Landlord or Management company.
@BrianAnnall  Is there heavy snow fall in the area, if so that would affect your satellite signal.
Samsung 75" 4K TV, Sky Glass Gen 2 55", Sky Stream, VM 1 Gig Broadband, Sony 7.1 AV Receiver, Technisat MultiSat receiver.
This message was authored by: caraleela72
yep... few hours now... reckon its just the storm clouds blockin the signal...
@caraleela72
Cloud cover problems are not likely to last several hours.
It is far more likely that the strong winds have moved your dish & will need re-aligning
