Discussion topic: Problem
This message was authored by: PMJ2024
Problem
Hi - we had to unplug our Sky Q box due to building works. I have plugged it in but it doesn't seem to work. It has a continuous red light. The TV upstairs doesn't work either now.  On the forums people say switch off and unplug then back on again but that doesn't work. Or press and hold the reset button on Sky Q but there is nothing that looks like a reset button on the Sky Q box. Indeed it has barely any buttons that you can press just one that looks like a "pairing" button. HELP! Don't want to miss the footy! Paul
Re: Problem
@PMJ2024 i knows you have said you have unplugged it and plugged it back in but sometimes you need to unplug it and leave it for 15 minutes then plug it back in
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
Re: Problem
Hi @PMJ2024 .
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
