Discussion topic: Hard Disk Fault
Message posted on 21 Jul 2023 02:39 PM
Hard Disk Fault
I've had Hard Disk Error messages 3 times in the last few weeks. Had to reset my box each time, losing all recordings, series links etc. Is there a permanent fix?
Message posted on 21 Jul 2023 02:59 PM
Re: Hard Disk Fault
@ATN1912 wrote:Is there a permanent fix?
A new box.
Message posted on 21 Jul 2023 04:29 PM - last edited: 21 Jul 2023 04:30 PM
Re: Hard Disk Fault
Sounds like you have tried the reset as described in this Sky Q help article for hard disk problems.
Looks like you need to get a replacement box, that you can order from the link at the bottom of the article;
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
When you return your faulty box, make sure you remove your Sky viewing card.
