Discussion topic: Handset
This message was authored by: MaggieG
Message posted on 26 Nov 2024 11:10 AM
Handset
The volume control on my handset isn't working nor is the blue search button
Find out more
Message posted on 26 Nov 2024 11:32 AM
Re: Handset
@MaggieG wrote:The volume control on my handset isn't working nor is the blue search button
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
The Q box has no concept of volume. The remote needs to be programmed to send volume signals to your TV.
