2
This discussion topic has been answered Discussion topic: Connecting wifi to new sky q box
This message was authored by: Krista3
Trying to set up new sky q box but will not connect to my sky router when holding the WPS button, any ideas?
Re: Connecting wifi to new sky q box
Hi @Krista3
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
Hi @Krista3
This message was authored by: DGARTY
You need to treat it as a third-party router and enter the password. The new router does not mesh so simply search for it in the Wi-Fi section and then enter the password
