Discussion topic: HLG with TCL screen
Message posted on ‎26 Oct 2024 03:46 PM
HLG with TCL screen
I have a TCL 55C815K and a new Q box as the last one decided to get very hot! If I try to view UHD channels the display brightness drops. Any ideas as to the best settings. In 10 bit mode set displays HGL and Dolby Atmos but is dark despite brightness on 100. its not so bad in 8 bit but then the set doesnt seem to use HLG settings. TIA
Message posted on ‎26 Oct 2024 03:57 PM
Re: HLG with TCL screen
Hi @David-clements-59 What is the hardware version of you new Sky Q box?
Message posted on ‎26 Oct 2024 04:09 PM - last edited: ‎26 Oct 2024 04:12 PM
Hi @David-clements-59 Are you sure that your TV supports HLG HDR? Looking at its specifications, HLG is not listed.
https://www.epey.co.uk/tv/tcl-55c815k.html
You should also note the maximum brightness is only 400 cd/m2. As a comparison, my old Sony was 1500 cd/m2. I would stick to 8 bit.
Message posted on ‎26 Oct 2024 04:26 PM
@David-clements-59 @MightyQuinn yet strangely Display specifications does state it's capable of HLG
https://www.displayspecifications.com/en/model/bed81f17
so assuming it is HLG capable one thing that we can say is that 400 cd/m2 is too low to get a decent picture through HLG 600 to 700 cd/m2 is the minimum and even higher as per @MightyQuinn is better
Message posted on ‎26 Oct 2024 04:38 PM
Yeah 8bit can't carry HDR. Has to be 10. But 400 nits is too low for HLG
HDR10 and DolbyVision are probably ok on it.
Message posted on ‎26 Oct 2024 05:07 PM
thanks for the info.. looks like the screen does work with HLG but just isnt bright enough.. now to persuade the missus that after 4 years we need a new set! PMSL
Message posted on ‎27 Oct 2024 09:40 AM - last edited: ‎27 Oct 2024 09:43 AM
Unfortunately the fundamental issue is that's a somewhat outdated edge-lit design rather than having an LED array behind the LCD panel. Current TCL models can be extremely bright.
