This discussion topic has been answered Discussion topic: HELP IN PAIRING SKY Q REMOTE
Message posted on 18 Sep 2025 04:14 PM
I'm having problems following the instructions for my new Sky Q remote.
Which button do I use to confirm answers? Also, No.3 instruction asks which remote am I using. Does it come with a drop down menu? (I haven't started doing this yet.) Any help would be much appreciated.
Message posted on 18 Sep 2025 04:56 PM
hi @SusanB2
I am not sure what instructions you are referring to, unless you are referring to the web page in the link below - you should not need to select the type of remote if you follow this:
To choose the TV, you navigate using the arrow buttons and confirm with the Enter/select central button
The chances are entering the TV model may not find it, so I generally recommend choosing the 'Find it for me option' which often works with one of the first few codes it tries
Even though it is a new remote I suggest you reset it first
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
hi @SusanB2
Message posted on 18 Sep 2025 05:31 PM
Re: HELP IN PAIRING SKY Q REMOTE
Thank you so much. I've now been successful in pairing my remote! 👍
Message posted on 18 Sep 2025 11:05 PM
Thank you for your help @nigea99 I've now successfully paired my remote.
