Discussion topic: HDMI port issue Sky Q
This message was authored by: Reevo87
Hello I have an issue with my sky Q box with the hdmi connection port which appears to of come loose, cable is loose when it’s plugged in, how can I have this resolved please?
Sky Glass Gen2 65"
Sky Air 43" in bedroom
LG 65" TV with Puck in spare room.
Broadband with Seethelight as on new build estate that does not support Sky.
Re: HDMI port issue Sky Q
Hi @Reevo87   It will probably need a replacement box, best to contact Sky.
Avatar for Reevo87
Level 3 icon
Thanks for your reply, any ideas of how much cost is involved please?
Sky Glass Gen2 65"
Hi @Reevo87   £zero, the box is simply loaned by Sky and will be swapped free.
This message was authored by: bob1234
@Reevo87Unless Sky think it is accidental or deliberate damage it should be free but Sky rarely seem to charge for damage.
hi @Reevo87
I have escalated your post to SKY who, hopefully, will be in touch.
Please see this link re the escalation and what you might see:
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
If you are using Safari I believe you must make sure that 'Hide IP adress' is not checked in settings to be able to see it - if you have difficulty finding that setting then may be try accessing here with another browser
The team that support these forums I think should be able to assist - if not they will point you in the right direction
As @MightyQuinn says - if it needs fixing/replacing then being SKY Q this will be done as part of your susbscription at no extra charge (unless they deam the damage is not from normal use etc)
This message was authored by: Mr+Flibbles+86
Thanks for escalating this. We’ve sent an invite to chat.
