Discussion topic: HBO still has ads withTNT subscription
This message was authored by: RyanP27
I'm an existing subscriber to TNT sports, so have HBO max included although it still has ads. What's the difference between this & basic version I'd get with TNT subscription?
thought the whole point was I wouldnt get adverts?
Re: HBO still has ads withTNT subscription
Base 'free' sub is with ads.  You can upgrade to remove them.
This message was authored by: DaveDrizen
Your TNT subscription allows you to the have TNT sport section of HBO max app only. As a Sky Q subscriber with signature you also are intitled to have the basic entertainment with ads in HBO max app only for free . If you want you can upgrade this to "without ads" for  a extra fee. If you get you tnt sport though Sky and go to the  My Sky app and click on "my products" you will see HBO max listed twice, one for TNT sports and the other labled " Basic with add". If you want to upgrade to without adds just click this one (Basic with ads) and you will be taken to another screen which will give you the opportunity to up grade. As I said this will involve a extra charge and will invole you puting a credit or debit card details in. As this done as a separate subscription though Sky Marketplace to your  normal Tv subscription and will not be add to you tv bill.
Note tnt sports content will have ads regardless of whether you have hbo entertainment without ads
That's ok I though the original post he was asking about the entertainment package as TNT sports though the app has always had ads even when was on Discovery plus.
