Discussion topic: Need to close Sky account to unlink a channel?
This message was authored by: CK_GK
Hello,
Have been a Sky subscriber for 25yrs+.  Have most packages Sports, Cinema, Netflix as well as Signature.
However BT Sport, now TNT has always been via my BT account. Not a problem until today....
Account on Discovery+ site states:
Current Pass : Discovery+ Via Sky. Your Sky promoion has been applied to your subscription.
Changes to your subscription must be managed through the Partner.
From today, we cannot watch the Sport on the Discovery+ app on the TV (because Sky's Discovery+ package is now basic?)
But I have Discovery+ Premium via BT (TNT package) so I should be able to have access to it.
After 3 hours on the phone (to BT, Sky & Discovery+) ....I've established....
c/o BT: Sky needs to unlink Discovery+ from them, and then I can activate the TNT Discovery Premium package.
c/o Sky: Cannot unlink me from Sky Discovery - I either cancel all Sky services and start again...or contact Discovery+ to remove my account from Sky
c/o Discovery+: They cannot remove my account from Sky. Sky have to manage this.
Anyone else facing this issue? Do I seriously have to cancel all Sky packages to remove an add-on account?
Thank you
This message was authored by: Lisa-P1987
Re: Need to close Sky account to unlink a channel?
Lisa - Sky Tech Team Expert
This message was authored by: JohnnyMorocco
I have similar issue...but cancelled tnt now I can't access free discovery plus...discovery plus tell me they need sky to unlink it...but sky can't!
Avatar for CK_GK
My issue isn't resolved. The next day Sky contacted me via this thread. Was told it could be resolved. At the same time I was on the phone to Sky, passed from
pillar to post. Their conclusion was: cancellation dept can't unlink it, as it's not a paid add on; technical dept can't unlink it as they don't have the authority- was told to speak to Discovery again. Discovery said they can unlink it because it was set up by Sky, so Sky need to manage it.
Looks like my only solution is to cancel Sky, so looking at alternatives at the moment.
This message was authored by: cuke
@CK_GK wrote:
Hello,
Thank you
Can you not install the app on your tv and login using the BT credentials?
This message was authored by: ozsat
It simply sounds as if you pay BT for TNT Sports and not Sky - but watch Discovery+ on your SkyQ box and haver signed in using Sky account?
If so to unlink Discovery+ on the SkyQ box you have to:
go into the app as usual
Move to the far left menu and then select 'Account'
Select 'Sign Off' and Sign Off - this disconnects your app from the Sky account
Now re-sign into the app - but you sign in with your BT creditials (as said above) and NOT your Sky account credentials
When you get the activation code on the SkyQ box - you must be logged into to your BT Account online in Discovery+.
So it is worth signing out online - and resign in using BT account details.
I used the manual sign in option - I can't get the QR code to load a valid page
@CK_GK wrote:
Hello,
Thank you
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
