This discussion topic has been answered Discussion topic: Gridlines Appearing on Sky Intermittently
Message posted on 13 Jul 2026 01:49 PM
Hi,
For many years I have had gridlines appearing on my TV as per the attached image. I have meant to get this resolved previoulsy but now I have moved house I know I can rule out the following:
- Several HDMI cables used in the past, always ths same
- 3 Different TV's
- Now different dish and cables in new house
- Picture Output Settings changes, 1080i, 1080p, etc
- HDMI Power turned off and on, same result
- Multiple channels tried, I would say it's all HD channels
Any suggestions on what might be causing this issue?
Message posted on 13 Jul 2026 03:31 PM
@Nookey wrote:Easier said than done - Impossible to speak to anyone and just go round in a loop on the website.
I don't want to book an engineer visit, although that seems to be broken as a link too, as I've had two visits to set up sky in the new house and neither could diagnose or fix the issue.
Follow the troubleshooting here and click the I Need More Help button - there's often a live chat link or the option to order a replacement box which will be brought via courier so you can swap it yourself. Remember to remove your viewing card from your current box before swapping them.
Message posted on 13 Jul 2026 01:56 PM
Re: Gridlines Appearing on Sky Intermittently
I forgot to add, this only happens with the Sky Q main box, mini-boxes don't have this issue.
Message posted on 13 Jul 2026 02:32 PM
@Nookey wrote:Hi,
- 3 Different TV's
It's clearly a bad Sky Q box. Contact Sky and get it replaced.
Message posted on 13 Jul 2026 03:25 PM
