Discussion topic: TV Channel asking for pin, where do I find pin?
Message posted on 18 Aug 2023 11:07 AM
Some TVchannels ask for a PIN code. What does this mean and where do I get this pin?
Message posted on 18 Aug 2023 11:11 AM
Re: TV Channel asking for pin, where do I find pin?
The PIN code is normally the last 4 digits of your viewing card.
Message posted on 18 Aug 2023 11:13 AM
Thank you for your response, where do I find viewing card?
Message posted on 18 Aug 2023 11:17 AM
On your SKY Q main box go to Home ~ Settings ~ System info.
Message posted on 18 Aug 2023 11:20 AM
In addition you should be able to change it to one more easily remembered
https://www.sky.com/help/articles/your-pin-sky-q-change
Message posted on 18 Aug 2023 12:05 PM
Thanks. Tried several times to change on Sky box, using correct pin; didn't work, was locked out. Have changed it online now and curious if that works. Do we pay for viewing stuff that is only accessible with a pin? Thanks again for your help!
Message posted on 18 Aug 2023 12:08 PM - last edited: 18 Aug 2023 12:37 PM
The channels which use a PIN because they are carrying post-watershed content before 21:00 are all subscription services: primarily Sky Atlantic, Comedy, Documentaries and various Sky Cinema options.
There's no additional cost on top of the subscription after entering a PIN unless the content is Box Office PPV (typically an advertised one-off live sporting event) or a film rental/purchase from Sky Store
Message posted on 18 Aug 2023 12:33 PM
Ok, thanks so much! Will see if pin works now.
