Discussion topic: Got a faukt code MR104
This message was authored by: Callie23x
Got a fault code MR104
Re: Got a faukt code MR104
Hi @Callie23x
If this is on a mini then it is a connectivity issue.
If this is the case first try rebooting the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
