Discussion topic: my sky q box keeps cutting out the picture goes off and leaves the backing home screen on
This message was authored by: Jon+gibbo20
My Sky q box keeps making a funny noise a d cuts out or the pixture dispears and leves the home screen on i ha e to keep turning my box on and off to sort
Re: my sky q box keeps cutting out the picture goes off and leaves the backing home screen on
Hi @Jon+gibbo20
