Discussion topic: Frozen picture but still have sound
This message was authored by: JAKid
My sky+ box picture freezes but still get the sound. Have to turn box off and back on. It happens after I ignore the tv and don't turn it on for more than 24hrs but sometimes still doors it. Sky+ Software q220.000.23.00L Hardware 3C009 HDMI TV to box No RF.
Re: Frozen picture but still have sound
The latest Sky+ software is R024 . 092 . 11 . 00P, it look more likely you have Sky Q
Edit: Your thread has been moved to the correct forum
I am NeurodivergentFAQs: Sky Glass Sky Stream Sky Go Sky Plus
Hi @JAKid
I have just removed your Duplicate post.
No need to start another thread as @Annie+UK  has moved your post to the correct Forum (Sky Q).
@oldfella It was moved but not by me 🙂
Hi @JAKid
Avatar for JAKid
Level 2 icon
Thank you.
Done that.   24hrrs and we will see.
Thanks again.
