Discussion topic: Film4 not available. '
This message was authored by: LouP1970
For Film4 and Film4 +1 it is saying 'This is film 4' but no films are showing
Re: Film4 not available. '
Same here - looks like a scheduled down time or issue their end.
Films are definitely showing, "Hotel Transylvania 3" is on now, but there are no EPG listings other than "This is FIlm4".
This message was authored by: Jimbo2023
Still no EPG listings for Film4 on Sky Q ...I wonder when someone in Sky will notice...
This message was authored by: Dee271
As the "this is film 4" listings are showing recordings for this channel are not working properly and films cannot be found using the search function.
Can they fix this pronto?
This message was authored by: mappion
Although I hate to be on Skys side on this, this is likely to be more likely down to the Film 4 broadcasters. Also if you move forward on the planner to tomorrow morning you will see that from 6am all the descriptions of what is on are back.
Thanks, just assumed this would be an issue with Sky!
This message was authored by: Blabyfox1
Same on ours
Same as ours. 😔
This message was authored by: upinthestars
Film 4 & plus 1 are working on freeview as iv just checked it seems like its jyst sky that its disappeard on ....come on sky get it fixed
Avatar for LouP1970
Level 2 icon
Thank you everyone for your prompt responses. Very much appreciated
This message was authored by: Susan+jobbins
Film 4 is not working on sky I missing this channel
