Discussion topic: Faulty sky signal
Message posted on 10 Jan 2024 07:57 PM
Faulty sky signal
When I launch Sky tv I see the usual menu screen but in all the wrong colours and the screen is flashing
Message posted on 10 Jan 2024 08:11 PM
Re: Faulty sky signal
Hi @PeterJW
