Discussion topic: Our control is not working. I’ve tried trouble shooting, but it’s not lighting up
Message posted on 10 Jan 2024 08:29 PM
Hi our sky remote for the sky box in our bedroom isn't working.
I've replaced the batteries but it still isn't lighting up.
Message posted on 10 Jan 2024 08:37 PM
Re: Our control is not working. I’ve tried trouble shooting, but it’s not lighting up
Try completly resetting your Bluetooth remote.
Failing this
Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment.
In the meantime if you have an Apple device with Sky Go you can set up a virtual remote to control your Q boxes.
See following link.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
