Discussion topic: Sky channels not working
Message posted on 19 Mar 2024 11:38 AM
Some of my channels aren't playing saying no satellite signal but some are okay
Message posted on 19 Mar 2024 11:59 AM
Re: Sky channels not working
@MG7266 Have you followed the steps here? https://www.sky.com/help/articles/sky-tv-no-satellite-signal-check-q
Message posted on 19 Mar 2024 12:25 PM
@MG7266
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
It’s not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
