Discussion topic: Faulty sky box
Message posted on 01 May 2024 06:35 PM
Faulty sky box
My sky box has gone off completely. There are no lights on the box to indicate it has any power. I have rebooted it by the main switch a few times and nothin.
Message posted on 01 May 2024 06:39 PM
Re: Faulty sky box
Hi @Claireo6
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Re: Faulty sky box
Hi @Claireo6 Have you checked the fuse and ensured everything is connected properly.
