Discussion topic: Faulty remote control
This message was authored by: Brackley+Man
I had sky q installed yesterday and the remote has stopped working. Tried new batteries but it's dead. Tried a friend's remote and it paired and worked on my new box no problem so my remote needs replacing although only 1 day old
Re: Faulty remote control
@Brackley+Man
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken or faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (I’m not sure if this is available to customers in the Republic of Ireland).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer / larger supermarket. If you do that as well as the above you’ll have a spare.
In the meantime if you have an android or Apple device with Sky Go you can possibly set up a virtual remote to control your Sky Q box. See this link which may help
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
Avatar for Brackley+Man
Thanks. I am trying to find a way to contact sky but phones not getting answered after an hour. I'm not paying for a remote myself when my equipment is only 1 day old
Check the post before yours (the link).
hi @Brackley+Man
Have you tried resetting your remote ?
if not, may I suggest you do try a reset of your remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
@Brackley+Man
@Brackley+Man
I agree. The advice about buying one was purely based on obtaining a spare and that it might be quicker.
