Discussion topic: Faulty mini box
Message posted on 02 Jan 2025 03:31 PM
Faulty mini box
Sky Q mini box has stopped functioning correctly. It is extremely slow to change channels etc , remote doesn't work most of time
Message posted on 02 Jan 2025 04:21 PM
Re: Faulty mini box
@Lin19
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Message posted on 02 Jan 2025 05:14 PM
Re: Faulty mini box
I'm still waiting after 90 minutes for chat to start
Message posted on 02 Jan 2025 05:15 PM
Re: Faulty mini box
Sorry tried all that no joy. Have been having problems for a few weeks
Message posted on 02 Jan 2025 06:04 PM
Re: Faulty mini box
@Lin19 Afraid you are not contacting Sky's customer services on here, this is a customer to customer forum where customers help each other.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 02 Jan 2025 07:46 PM
Re: Faulty mini box
hi @Lin19
Try a Network Reset on the mini.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the reset button.
You could also reset your mini remote.
With the mini box on with green led press and hold 7 & 9 together on the remote until it’s led flashes four times.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
