Discussion topic: Can't get volume to work on sky remote on new Samsung TV
Message posted on 02 Jan 2025 07:58 PM
Tried the press 7 and 9 buttons to reset the remote. Light flashes. But the next step of pressing buttons 1 and 3 does nothing. All buttons other than volume work. Any other suggestions please?
Message posted on 02 Jan 2025 08:11 PM
Re: Can't get volume to work on sky remote on new Samsung TV
Hi @TD1211
Message posted on 02 Jan 2025 08:27 PM
As said above I've done that. 1st step works but the 1 and 3 part does nothing.
Message posted on 02 Jan 2025 08:31 PM
There are no on screen instructions.
Message posted on 02 Jan 2025 08:35 PM
Just kept trying and it's finally worked. Thank you.
Message posted on 02 Jan 2025 08:43 PM - last edited: 02 Jan 2025 08:45 PM
hi @TD1211
Edit our last posts crossed.
Assume you are OK now and can ignore the following.
The Television needs to be on and switched to the Correct HDMI input
First reboot the Q box.
Have you tried rebooting your Q box?
Then with the Q box on with green led.
If the remote led flashes 4 times when you press and hold 7 & 9 together on the the remote it is in infrared mode and not paired to Q box or television.
Assuming the television is still on displaying Sky content or Home screen the you must point the remote directly at the Q box sensor and press and hold 1 & 3 together. The remote should flash and you should see onscreen instructions.
