Discussion topic: Faulty SkyQ remote.
This message was authored by: Billyaugust
Faulty SkyQ remote.
The navigation buttons are sticking. Can I get the remote replaced or fixed
Re: Faulty SkyQ remote.
@Billyaugust try following the link below
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
@Billyaugust
It may be quicker to purchase a new remote from a retailer / larger supermarket. If you do that as well as the above you’ll have a spare.
In the meantime if you have an android or Apple device with Sky Go you can possibly set up a virtual remote to control your Sky Q box. See this link which may help
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
