1
This discussion topic has been answered Discussion topic: Sky mini box
This message was authored by: Sheena26
Sky mini box
Connected to internet but sky mini box will let you watch Netflix but not sky says technical problem
Re: Sky mini box
Hi @Sheena26
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Re: Sky mini box
Hi @Sheena26
