Discussion topic: Fast forward problems
This message was authored by: jrwfsl147
Recently upgraded to Sky Q and unless I'm missing something it seems to be a lot less convenient for someone looking to fast forward.
The first problem is that there appears to be no way to skip to a specific point in the broadcast, you have to start from the beginning and manually fast forward from there.  I had the snooker on record yesterday, the match I wanted to see was three hours into the broadcast so it took me five minutes to get there.  In prior Sky boxes you could manually select where in the broadcast you wanted to skip to.
The second problem is that the fast forward icon covers the bottom third of the screen, whereas prior Sky boxes just had a pause icon in the bottom corner and the rest of the screen was unimpeded.  This means that I can no longer watch the snooker on fast-forward as the bottom third of the table is completely unviewable.
Is there anyway around either problem?
This message was authored by: Invisiblename
Re: Fast forward problems
@jrwfsl147  Your first issue is easy, use voice control & say "Fast Forward 3hrs"
I am just another Sky customer!
Avatar for jrwfsl147
That's marvellous, thanks.
@jrwfsl147  Further to that, you can use the voice control to 'fine tune' your search .e.g Fast Forward 3 hrs, followed by Rewind 3 mins, or even Rewind 10 seconds.
@jrwfsl147 as @Invisiblename has dealt with the first part of you query.
The second part is just as easy when you know how. After pressing fast forward press the dismiss button the one to the left of the home button and it will remove the icon 😁
hi @jrwfsl147
As the others have said voice control is your friend here - my favourite commands are:
Skip nn minutes
Go To nn minutes
Back nn minutes
You can use hours, minutes & seconds or mix e.g. Go to 1hour 15 minutes
Skip nn minutes is very handy for adverts and you get used to the length on regular used channels (Many are around the 4 minute mark)
You can also say Go To Start
Voice control in general is very useful - see
https://www.sky.com/help/articles/sky-q-voice-control-commands
Hi @jrwfsl147   Just to give you an alternative to voice commands, Press Pause, then hold down the DirectionRight key to slew over to your 3 hours point in a few seconds. Each single press of the Direction keys moves one minute forwards and backwards.
This message was authored by: SGu3
After many times trying saying likes of  "fast forward 30 minutes" into my Sky Remote and it not recognising what I said in my Scottish accent I gave up. Then I read somewhere that "skip" was recognised. "Skip 30 minutes" works perfectly every time.
Why oh why isn't there a button to enter a custom fast forward time?
Hi @SGu3   Are you muting the sound and holding the remote about 30cm (12 inches) away?
Note Fast Forward is a transport command, if you want to move forward a set number of minutes, you should use the Skip command.
This message was authored by: Rabbitoh
Thank you for your wisdom. however Sky should note even that does not work when there is a major problem with the item itself.
I set the Rugby France v Maoris to record. I had watched it all the way through to half time when it threw me out. I tried using the 'continue' function to pick up where I'd left off and it took me back to the start. I tried this again and used voice commands etc. but every time it would not go past the half way point. Majorly frustrated. It is absolutely irritating. I understand why you want to make us watch the adverts but it is really annoying when you can't watch the thing you actually recorded!
