Discussion topic: Failed recordings
This message was authored by: DELIGHTFUL+DELORU
Failed recordings
It keeps saying fail recordings, everything has failed
This message was authored by: Doc5907
Re: Failed recordings
@DELIGHTFUL+DELORU
Try to reboot your Q box.
Press Standby on your Sky Q remote and then switch off and unplug at the mains.
Wait at least 30 secs and then switch your Sky Q box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait a few seconds before you press Home on your Sky Q remote which should change the light to green and home screen should appear.
Sky Q 1TB UHD
LG TV
Sky Mobile
@DELIGHTFUL+DELORU i have moved your duplicate post 😀
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
