This discussion topic has been answered Discussion topic: FRANCE 24
Message posted on 31 Dec 2025 09:28 AM
Hi has anybody else experienced low sound output from FRANCE 24 through the Sky Q box?
Output from the mini box is normal.
Message posted on 31 Dec 2025 11:36 AM
Are the sound settings the same on both boxes? Particularly normal / DD.
Message posted on 31 Dec 2025 10:33 AM
Re: FRANCE 24
hi @BIGGS666
I don't know about earlier but I have just watched a few minutes & found the sound fine - in fact very slightly louder than a couple of other news channels
Message posted on 31 Dec 2025 02:23 PM
Re: FRANCE 24
I've just checked and the volume is way down from the Sky Q box than it is from the mini box.
Every other channel is fine, normal output.
Message posted on 31 Dec 2025 02:45 PM - last edited: 31 Dec 2025 02:48 PM
Re: FRANCE 24
Hi @BIGGS666 What have you set your Audio format in the settings? Normal? I cannot check it, as my TV has automatic volume, so different volume levels from different inputs will always have the same volume.
Message posted on 31 Dec 2025 02:52 PM
Re: FRANCE 24
Everything has been working fine for years. and now for the last couple of days the volume is reduced.
All the settings remain the same, 1 channel with reduced sound is not a settings issue.
Message posted on 31 Dec 2025 03:19 PM
Re: FRANCE 24
@BIGGS666 wrote:Everything has been working fine for years. and now for the last couple of days the volume is reduced.
Viewer relations would be the first port of call: viewerR@sky.uk
But it may be the feed the channel itself is providing.
Message posted on 31 Dec 2025 03:31 PM
Re: FRANCE 24
Thankyou.
Message posted on 31 Dec 2025 04:04 PM
Re: FRANCE 24
As the sound is OK on the mini box & OK for others (including myself) it is not a channel issue & thus no real point in writing to Viewer relations
@BIGGS666 not sure why it would be lower volume on your main box
BTW I just tried switching to Normal from Dolby Digital and this is louder thanwhen using DD
Message posted on 31 Dec 2025 04:16 PM - last edited: 31 Dec 2025 04:16 PM
Re: FRANCE 24
@nigea99 wrote:As the sound is OK on the mini box & OK for others (including myself) it is not a channel issue & thus no real point in writing to Viewer relations
Fair point. As the audio is served digitally then the Q has no 'volume' as such - the decoding device does the D-to-A conversion and amplification.
Notwithstanding some bizarre software/hardware fault on the main Q then the problem could be off the box - however, this doesn't explain a single channel issue... I would assume the main Q box has been power cycled as this sometimes clears out bizarre behaviour.
Message posted on 31 Dec 2025 06:47 PM
Re: FRANCE 24
Thankyou. When I alter the output from Dolby Digital or Dolby Digital + into Normal the sounds then goes to normal output level maybe due to FRANCE 24 Output, I will have a play about with the settings on my Marantz 8012 settings.
