Discussion topic: Ethernet cable removed I
This message was authored by: David1955
Sky Q box installed plus new router. Ethernet cable and box removed which connect to desktop computer
Re: Ethernet cable removed I
@David1955  Do you have a question?
Do you mean the installation technician removed your ethernet cable and a switch that used to sit between your PC and router?
