Discussion topic: Error code MR102 and MR101
Message posted on 06 Sep 2024 12:00 PM
Sky mini box in kitchen stopped connecting to main broadband box. Internet not working in kitchen.
Message posted on 06 Sep 2024 12:32 PM
Re: Error code MR102 and MR101
Hi @MartinDaubs
Reboot the mini as above.
