Discussion topic: Error code MR102 and MR101
This message was authored by MartinDaubs This message was authored by: MartinDaubs
Sky mini box in kitchen stopped connecting to main broadband box. Internet not working in kitchen.
Re: Error code MR102 and MR101
Hi @MartinDaubs
Reboot the mini as above.
