Discussion topic: Error Netflix code tvq-pb-101 (5.6.1)
Message posted on 20 Feb 2025 02:55 PM
I cannot get my Netflix to work on main sky box and the error message is as per title. The onscreen errors are try unplugging device or there's an issue with your streaming device.
I am going around in circles on logging out and back in and reloading and I've follows all the steps on sky and Netflix help with software etc.
it's working fine on the mini box so how's that possible?!
please help!
Message posted on 21 Feb 2025 08:46 AM
Re: Error Netflix code tvq-pb-101 (5.6.1)
Message posted on 21 Feb 2025 09:06 AM
@DKP13 wrote:I cannot get my Netflix to work on main sky box and the error message is as per title. The onscreen errors are try unplugging device or there's an issue with your streaming device.
I am going around in circles on logging out and back in and reloading and I've follows all the steps on sky and Netflix help with software etc.it's working fine on the mini box so how's that possible?!
please help!
Have you tried talking with Netflix & sharing the code with them?
Message posted on 22 Feb 2025 04:45 PM
Hi, yes I've tried Netflix and they said speak to sky and the sky help says to speak to Netflix 🤷🏻♀️
Message posted on 22 Feb 2025 04:46 PM
Hi, I've only just seen this message. Can you please escalate again as I think I missed the chat? Thanks
Message posted on 22 Feb 2025 05:52 PM
@DKP13 wrote:Hi, I've only just seen this message. Can you please escalate again as I think I missed the chat? Thanks
Chat bubble should still be available, it lasts for 48hrs
Message posted on 23 Feb 2025 09:38 PM
I am also seeing this error whenever I try and play anything on Netflix on the main. Sky Q box, "tvq-pb-101 (5.6.1)".
I have reset the box, router, waited minutes, logged out and back in. Closed the app, refreshed the apps and checked on the Netflix help pages. Nothing has changed, I get the same error and Netflix just say to contact Sky. Does anyone have a fix for this?
Message posted on 21 Apr 2025 09:16 AM
Recently started getting this constantly on Sky Glass. Restart the TV and it works for a few minutes and then the screen goes black with audio still playing. Try to restart the app again or switch to watching another app and when going back to Netflix get this error again.
Message posted on 16 May 2025 01:38 PM
I am having the same issue since last night
Message posted on 16 May 2025 02:15 PM
This is a main Sky Q box issue not a Netflix problem. It was happening to me on Disney plus too.. You need to follow the guidance online to reset your apps on the box from the engineers 001 menu. I did this, it wiped all the apps off the box. Eventually after 30 mins they all reappeared. I launched Netflix, logged back in and they started working again.
Message posted on 16 May 2025 07:07 PM
I have done this and still not working with same Netflix error code
Message posted on 16 May 2025 10:35 PM
I found the original fix I used. It involves resetting some of the settings not refreshing the apps. I did not lose any recordings when I did this but had to reset the av settings afterwards. My remote also continued to work without having to be re-paired up. This deletes the apps and then they reloaded...
