Discussion topic: Sky Q box and mini box not working since last night
This message was authored by: Flowers4
Last night Sky kept freezing tried turning it off several times but still not working went to bed came home this evening after a long day and still not working I tried switching it off loads of times but still not working
Re: Sky Q box and mini box not working since last night
Hi @Flowers4
Try a Reset Settings in the main Q box hidden menu.
