1
This discussion topic has been answered Discussion topic: Error Message MR102
This message was authored by: IDS7
Error Message MR102
I have had the same error message on both my sky q mini dishes for months now and have followed all of your online hints etc but with absolutely no result. This is not the first time this has happened and I needed an engineer the last time. Can I arrange for an engineer to call please.
Re: Error Message MR102
@IDS7
If you are new to the forum then welcome to the Community, which is predominantly made up of Sky customers helping other Sky customers. You aren’t talking to Sky by posting here.
Sky won't contact you as a result of your post and won't know who you are as your Sky accounts aren't linked to your Community username.
It’s always worth starting with a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Also see this link here
https://helpforum.sky.com/t5/Sky-TV/Error-Codes-on-Sky-O-and-Glass/ba-p/4017045
@IDS7
Answered - Go to Answer
